Community Member
Log files
Does any one have any idea which traces should be collected for issues call failure issue or any other logs i mean for all the logs which can help isolate issue's
Like few days ago i was facing issue upgrading the CUCM server so i took install logs to isolate the issue.
So my question is how many kinds of logs we have and which one to use for resolving the issue.
Thanks in advance.
Everyone's tags (2)
Hall of Fame Super Silver
Log files
Collect the "CallManager" service traces.
Chris
Community Member
Log files
How do you view the text files though? I've always wondered that, I just send them to TAC but I'd like to be able to look at them. When I open a CM trace file in notepad, notepad++ or word pad, it's just a bunch of character.
I think I can view within RTMT (browse) why can't I seem to open the text files?
Log files
They should be readable from the text editor just fine. Not sure why it is showing this for you :-(
Chris
VIP Super Bronze
Re: Log files
Joshua,
Most times the files are zipped with a .txt extension. You need to use a zip file extractor such as winzip or 7zip to extract them before you can use notepad++. If you try to open it direclty it will show as scrambled as it is now
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Re: Log files
Thanks aokanlawon, I was using WinZip (paid version) when I was getting the results above. I forgot about 7zip, but downloaded it and now I can view the file!
Not sure why WinZip wasn't working, it seems to work for decompressing other zipped files. Probably some sort of PC issue. Thanks!
VIP Super Bronze
Log files
Glad to help, dont forget to rate useful posts
331
