Community Member
Log in / out of hunt group
I would like for users in a hunt group to be able to log in and log out. Is there a softkey that will enable this feature.
We're running CCM5.1. I know softkey "HLog" is available on CCM 4.x but not on 5.x.
Marvin
Re: Log in / out of hunt group
The HLog feature is not in all 4.x, just in 4.2(x). It's also available in 6.x, since 4.1(3) was the version they used as base for 5.x that's why it's not there
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Is there a workaround for 5.x users?
the way we used to make this would be using EM for this purpose, when they log into EM they will be available, if not logged into their EM profile they were offline on the group
java
Hall of Fame Super Gold
Not sure why the low rating to the post above that has correct and complete information.
My rating, a '5'.
Community Member
I was looking for a workaround solution as replied on my next post. Gave HTH another 4 pts for a quick answer. Thanks HTH!
Marvin
256
