'logged out (default) profile information' config on UDP?
I'm struggling to understand the option of setting a 'logged out (default) profile information' end user on the user device profile configuration page.
Looking at the CUCM web pages and the Cisco documentation I still can't clearly understand what it is used for.
I've tried various configurations in the lab but can't see how it works.
Can anyone give an explanation in simple terms so that I can understand its operation.
Mark
UDP
You can assign a user device profile to a user so that when a user logs  in or out of a device, the corresponding user device profile is loaded  onto that device. .
Take a look
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_1_2/ccmsys/a07hotel.html
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080093e72.shtml#prof-3a
Is like a logout profile and login profile
Thanks for the reply.
I'm still struggling to understand why you'd configure the information on the UDP.
Scenario:
A user is logged in to a handset with his associated user device profile (End User - JSmith with UDP with DN 1001).
JSmith's user device profile has a 'logged out (default) profile information' assigned  to another End User ID (PBrown).
PBrown end user account is associated with a UDP with a DN of 2001.
When JSmith logs out of the phone (which currently has DN 1001) the phone will re-register with the UDP of PBrown with the Extension of 2001??
If this should be the case I can't get it to work.
Mark
Extension Mobility (EM) feature enables users to configure a Cisco Unified IP Phone as their
own, on a temporary basis, by logging in to that phone. After a user logs in, the phone adopts the user's
individual device profile information, including line numbers, speed dials, services links, and other
user-specific properties of a phone.
Take a look
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b2f.shtml
When you log in a phone you use the UDP that is associated with a end user, when you log outs you dont use the UDP.
Thanks again,
But that's my point, why would you configure the 'logged out (default) profile information' on the UDP?
"When you log in a phone you use the UDP that is associated with a end user, when you log outs you dont use the UDP."
I can't understand the purpose of this setting.
Mark
Re: 'logged out (default) profile information' config on UDP?
Mark the purpose of logged out profile is is the profile which gets loaded on the  phone when a user logs off. So you have the option to create logged  off device profiles instead of configuring the dn/pt/css settings fixed  on the phones.
I suggest you take a look on the login/ logout flow to help you understand
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_0_1/ccmfeat/fsem.html#wp1241822
I can understand how assigning a logged out profile on the device itself would work but it's still not clear why you'd set out a logged out profile on the UDP itself.
From my tests when I log my profile out of a phone, the device doesn't pick up the profile info that is assigned under my UDP (logged out (default) profile info field).
Instead the device picks up the profile assigned to the phone itself (Extension Mobility>Log out profile field).
Forgive me if I'm missing the relevant detail in the documentation, but I still don't understand when the logged out profile on the UDP is invoked.
Thanks.
491
