logging outgoing call
Hi, in my Cisco 1760 with IOS 12.2(15)ZJ3 (IP/VOX PLUS c1700-sv8y-mz) each time an incoming call is present, a log message is generated as this:
Jul 31 15:38:20: %ISDN-6-DISCONNECT: Interface BRI0/1:1 disconnected from 171634119 , call lasted 199 seconds
The problem is that the outgoing call are not logged in a similar way, maybe because i have not understood how to configure the router.
How can i get a log each time an outgoing call is done, with the called phone number ?
Thank'You and Best regards
1 ACCEPTED SOLUTION
Re: logging outgoing call
Give a look to the following document http://www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/ftvdsplg.html
Maybe this will help.
Thank You. The document is very helpful and show a valid solution.
207
