08-06-2009 12:06 AM - edited 03-15-2019 07:15 PM
I have 2N ISDN LITE GSM Gateway. Two sim cards with some free minutes. I want to load balance between both cards. There is a thick that on the GSM GW that says 1 SIM on 1 B-chan, 2 SIM on 2 B-chan. I'm wondering is it possible to configure logic of selecting ISDN BRI channels for example longest idle.
Any other advices will be greatly appreciated.
Thank you.
08-06-2009 01:18 AM
No, router will always choose the highest free channel on a single BRI.
It would be possible, via trunk-group, when using multiple BRIs.
08-06-2009 05:44 AM
It can be possible on gateway it self. Got SIP GSM gateway where I can implement some logic. Not sure about your model tho.
08-06-2009 06:02 AM
We tried with the GSM gateway but it doesn't work. There is something written in the data sheet but there isn't documentation about it.
Now I will try to do it by prefix. For example 50% of the end users will prefix the calls with 7 and 50% with 8. The calls started with 7 will be routed to the first card and with 8 to the second.
I hoped for smarter configuration but there isn't way.
Thank you.
