Login is unavailable (23) EMCC
HI,
I have configured EMCC on my three cluster successfully with no error while validating the configuration. But when i tried to login to the 7942 phone, it gives me an error "login is unavailable (23) "
Please help me with this.
Pawan Arora
Everyone's tags (3)
VIP Super Bronze
Pawan,
Have you enabled EMCC for the user ?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Yes, it is enabled the EMCC for the end user
I have genrated the logs for EM from call manager. Below are the logs
2012-07-18 14:19:48,484 INFO  [http-8443-17        ] EMServiceServlet          - EMService Request# ----> : 1925
2012-07-18 14:19:48,485 INFO  [http-8443-17        ] EMServiceServlet          - 1925:EMService: Request Type=EMCC
2012-07-18 14:19:48,488 INFO  [http-8443-17        ] EMServiceServlet          - 1925: processEmccRequest: Received EMCC Login Request for :4080
2012-07-18 14:19:48,488 INFO  [http-8443-17        ] EMServiceServlet          - 1925: Executing authenticate2...
2012-07-18 14:19:48,489 INFO  [http-8443-17        ] EMServiceServlet          - 1925: authenticate2: Authenticate request.
2012-07-18 14:19:48,489 INFO  [http-8443-17        ] Authenticator             - 1925:Authenticator.authenticateTransaction: AppID: CCMSysUser- Checking values in credential cache
2012-07-18 14:19:48,489 INFO  [http-8443-17        ] Authenticator             - 1925:Authenticator.authenticateTransaction: AppID: CCMSysUser- Approved through credential cache, 109346 ms remaining
2012-07-18 14:19:48,489 INFO  [http-8443-17        ] EMServiceServlet          - 1925:EMService Authentication succeeded
2012-07-18 14:19:48,489 INFO  [http-8443-17        ] PolicyValidator           - 1925:PolicyValidator.checkDeviceAllowsLogin: Dev: SEP3CCE7359CA5C- Calling dbr.getDeviceObject
2012-07-18 14:19:48,490 INFO  [http-8443-17        ] DBRequestor               - 1925:Getting device object - loginInfo, caller
2012-07-18 14:19:48,490 INFO  [http-8443-17        ] DBRequestor               - 1925: PolicyValidator.checkDeviceAllowsLogin: Dev: SEP3CCE7359CA5C- Getting device object
2012-07-18 14:19:48,492 INFO  [http-8443-17        ] CMDatabase                - CMDatabase:getDeviceInfo: SELECT device.pkid, loginduration, decode(extensionmobilitydynamic.logintime, null, emremotedynamic.logintime, extensionmobilitydynamic.logintime)logintime, allowhotelingflag, extensionmobilitydynamic.fkenduser, decode(extensionmobilitydynamic.fkenduser, null, remoteuserid, e2.userid) currentuserid, fkenduser_lastlogin lastloginpkid,decode(fkenduser_lastlogin,null,lastremoteuserid,e1.userid) lastuserid, extensionmobilitydynamic.tkuserlocale, fkdevicepool, tkdeviceprotocol, tkproduct, tkmodel FROM Device left outer join extensionmobilitydynamic on device.pkid=extensionmobilitydynamic.fkdevice left outer join emremotedynamic on (extensionmobilitydynamic.fkdevice=emremotedynamic.fkdevice) left outer join enduser e1 on (extensionmobilitydynamic.fkenduser_lastlogin=e1.pkid) left outer join enduser e2 on (extensionmobilitydynamic.fkenduser=e2.pkid) where my_lower(device.name) like my_lower('SEP3CCE7359CA5C')
2012-07-18 14:19:48,498 INFO  [http-8443-17        ] CMDatabase                - getDeviceInfo:Device query executed
2012-07-18 14:19:48,498 INFO  [http-8443-17        ] CMDatabase                - getDeviceInfo:Result of the query: {tkproduct=333, loginduration=, lastuserid=6341, tkdeviceprotocol=0, pkid=e5760774-a54d-4245-8c77-cffc00061368, fkenduser=, tkmodel=434, logintime=, lastloginpkid=81692854-5108-4fc1-87b5-789bd9f9a507, currentuserid=, allowhotelingflag=t, fkdevicepool=032a0acc-ef20-1030-4523-dd9ddbde69fa, tkuserlocale=1}
2012-07-18 14:19:48,498 INFO  [http-8443-17        ] DBRequestor               - 1925: PolicyValidator.checkDeviceAllowsLogin: Dev: SEP3CCE7359CA5C- Device object returned
2012-07-18 14:19:48,498 INFO  [http-8443-17        ] PolicyValidator           - 1925:PolicyValidator.checkDeviceAllowsLogin: Dev: SEP3CCE7359CA5C- dbr.getDeviceObject returned
2012-07-18 14:19:48,499 INFO  [http-8443-17        ] EmccData                  - osQuery = SELECT COUNT(*) as value FROM ProductSupportsFeature p INNER JOIN Device d on (p.tkProduct =  d.tkProduct AND p.tkDeviceProtocol IN (99, d.tkDeviceProtocol )) INNER JOIN TypeSupportsFeature t ON p.tkSupportsFeature = t.Enum WHERE d.name = 'SEP3CCE7359CA5C' AND t.Moniker = 'SUPPORTS_FEATURE_EMCC'
2012-07-18 14:19:48,502 INFO  [http-8443-17        ] PolicyValidator           - 1925:PolicyValidator.checkCurrentLogin: getCurrentLoginTime return value- 0
2012-07-18 14:19:48,502 INFO  [http-8443-17        ] PolicyValidator           - 1925:PolicyValidator.checkCurrentLogin: no user currently logged in
2012-07-18 14:19:48,502 INFO  [http-8443-17        ] EMServiceServlet          - 1925 findHomeCluster: Finding Home Cluster for User: 4080
2012-07-18 14:19:48,503 ERROR [http-8443-17        ] EMServiceServlet          - 1925: Userid not exist in this cluster
2012-07-18 14:19:48,503 INFO  [http-8443-17        ] EMServiceServlet          - 1925: EmccRequest Processing Time: 18
2012-07-18 14:19:48,503 ERROR [http-8443-17        ] EMServiceServlet          - 1925: Error processing EMCC request :Userid not exist in this cluster
It is just searching in the home cluster not in the remote cluster
Blue
Hi Pawan,
Below video shows the steps involved and you will get to know where you are doing things wrong.
https://supportforums.cisco.com/videos/1970
Go through the video and see if it helps.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
I have used the same video to configure the EMCC.
Hi All,
Hi All,
Though this is pretty old thread, thought I would post my experience with this error
" Login is unavailable (23) "
it may help someone.
I was getting this error despite  all services (EMCC, PSTN Access, TFTP etc) were showing activation status true for  remote  cluster.
Following procedure helped fix in my case.
1. Deleted remote cluster info on involved clusters (Advanced features --> Cluster View).
2. Changed cluster IDs for involved clusters. (System-->Enterprise parameters)
3. Created remote cluster view again on both the clusters and update EMCC Remote cluster now.(Advanced features --> Cluster View).
thanks!!!
I had a user in our heavily
I had a user in our heavily used mobility core site that was getting this error 23 which was not phone specific. It turned out he had changed his PIN and forgot. Resetting proved to solve the problem. Nice to find simple fixes!
Blue
also
Login is unavailable(23) =
When the end user configuration is absent in both local and remote cluster, or
- EMCC service is not enabled on remote cluster (HC).
(User is authenticated on remote cluster only if EMCC is enabled.) Click  Update Remote Cluster Now from VC Remote Cluster Configuration page and  check if HC's EMCC service is enabled.
Ronak patel
Rate helpful posts.
HI Ronak,
Emcc is already enabled on both the clusters. Do you want me to disable the services and re-enabled it on both the clusters
Pawan
Blue
HI
Have you created same user in two cluster and deleted that user in one cluster.
Ronak Patel
VIP Super Bronze
Here is an excellent video that shows how to enable/configure EMCC..See what step you are missing
http://www.youtube.com/watch?v=WBHwy6-Uebg
thats the same video which was shared by Ronak
Ronak,
there is one parameter "
Enable All Remote Cluster Services When Adding A New Remote Cluster " in EMCC feature configuration which is set to false. do i need to set it to true.
Pawan
no...user only exists in one cluster
Blue
HI
Oki. Are you able to log in same cluster using same user. Have you checked if same user is woking for normal EM.
It is not mandatory "Enable All Remote Cluster Services When Adding A New Remote Cluster"  to be true.
Ronak patel
Hi Ronak,
I have checked with the remote cluster, the user id is able to login to the phone
Pawan
Blue
Plesae restart all the three esrvice required for the EMCC mentioned in the video and see if issue gets resloved.
regards
Ronak Patel
Rate helpful posts.
ok Ronak, I will do that in the off buissness hours and will let you know about the same
Pawan Arora
Blue
HI
Also if you can send me screen shots offline for the each and every config done for EMCC  , I can see the issue form my side and test in the lab.
Ronak patel
Rate all helpful posts.
Ronak,
Please let me know the email id on which I should send you the screen shot
Ronak,
When i checked the remote cluster view it is showing Migrated 1 and Migrated 2 in cluster view.
Do you have any idea
Pawan Arora
Hi Ronak,
I have restarted the services but still not able to login
Don't know if you solved it, but for me it worked when i checked "home cluster" under CUCM administration, user mgmt, end user, service settings.
VIP Super Bronze
Hi, Have a look at this and see if it helps.
The Cisco Extension Mobility service in participating clusters performs a periodic remote cluster update. The EMCC Feature Configuration feature parameter, Remote Cluster Update Interval, controls the update interval, for which the default value specifies 30 minutes.
If the Cisco Extension Mobility service on cluster A does not get back a reply from a remote cluster (such as cluster B) for this update, the Remote Cluster window for cluster A shows that Remote Activated service is set to false for cluster B.
In this case, the visiting cluster does not receive any response from the home cluster and sets the Remote Activated values for the home cluster as false.
During this interval, a visiting phone may not be able to log in by using EMCC. The visiting phone receives the Login is unavailable (23) message.
At this point, trying to log in EMCC from a visiting phone may fail with the error, Login is unavailable (23), which displays on the phone. This occurs because the visiting cluster has not yet detected the change of home cluster Cisco Unified Communications Manager from out-of-service to in-service.
Detection of status change of remote clusters is based on the value of the Remote Cluster Update Interval EMCC feature parameter and on when the visiting Cisco Extension Mobility service performed the last query/update.
You can also click the Update Remote Cluster Now button on the Remote cluster Service Configuration window (Advanced Features > EMCC > EMCC Remote Cluster) to change Remote Activate values to true, which also allows EMCC logins. Otherwise, after the next periodic update cycle, EMCC logins by visiting phones will return to normal.
I understand this thread is a
I understand this thread is a few years old, but something to think about if anyone is having this trouble now with a 9.5 and up version of CCM. Remember to have the Home Cluster Check box checked to allow the Extension Mobility to work correctly.
Hi Jsbrown23,
Hi Jsbrown23,
It works for me.
Thanks.
10046
