Community Member
Logs
        Logs
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Outbound call logs - finding who called 911
Asuming you are using CUCM, you can pull the CDRs by going to Unified Serviceability > Tools >
CDR Analysis and Reporting > CDR. Export the CDRs to a CSV file and search calls to 911. You will find the Mac the call was made from.
Please rate helpful answers!
Community Member
Cisco Serviceability Reporter is not running but now I know  how. Thank you!
Community Member
You need to make sure CDR is enabled on each subscriber.  I also recommend enabling zero length CDR recording.  This insures records are generated for calls where users hang up quickly.
355
