Long Delay in IDD calls with FAC
We have cucm 9.1, we have IDD route pattens with FAC enabled, I noticed that there is a long delay when dialing IDD numbers, CUCM route patten 00!, in the VGW dial-peer has 00T, can we adjust this waiting time ?
can we adjust waiting time after entering FAC ?
Regds
  • IP Telephony
Everyone's tags (2)
Hall of Fame Super Silver
You can adjust the inter-digit timer by changing the T302 service parameter in CUCM under service parameters --> CallManager
HTH,
Chris
Change T302 or add # to route pattern like
00!#,
After  dialing number, press #.
As chris said its better to set T302 timer to 4000.
I guess this should solve ur problem.
154
