Long Display Time - Missed Call Info on device
Some of our users are complaining about the timing of the missed call information represented on their phones - "too long". We just upgraded our decive firmware to:
SCCP70.8-0-4ES6-0-1S
If you have multiple lines on your phone, for instance the missed all info first says “on 123-4567” than “today at 12:00p”. It takes ~5- 6 sec before the called time is displayed.
Is there a way to shorten the display time?
1 REPLY
Re: Long Display Time - Missed Call Info on device
i got the same question about a month ago, that 5 second timer is internal on the phone and is hard-coded, the behavior is WAD
java
if this helps, please rate
java
www.cisco.com/go/pdi
123
