Long Distance
We are in process of deploying IP phones for our remote sites. Each has there own gateway PRI/FXO.
The issue we are experiencing is outbound long distance calls. We receive a message that calls cannot be completed as dialed. We have created several route patterns 9.@ and 9.1XXXXXXXXXX and Discard Predot. We have verified that local calls are working fine and is going through the correct gateway. Anyone who has experienced this or know of any advise is appreciated greatly!
debug isdn q931 is ON.
paar1#ter mon
paar1#
Dec 8 17:44:05.685: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x000C
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2181, '7063127404'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '18005532447'
Dec 8 17:44:05.765: ISDN Se0/1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8
00C
Dec 8 17:44:05.769: ISDN Se0/1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x80
0C
Cause i = 0x8281 - Unallocated/unassigned number
Progress Ind i = 0x8288 - In-band info or appropriate now available
Dec 8 17:44:07.709: ISDN Se0/1/0:23 Q931: TX -> FACILITY pd = 8 callref = 0x00
0C
Facility i = 0x9F8B0100A1080201010201008400
0xA1080201010201008400
Invoke Id = 1
Operation = CallingName
Name not available
Dec 8 17:44:14.237: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x
000C
Cause i = 0x8090 - Normal call clearing
Dec 8 17:44:14.265: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x800
C
Dec 8 17:44:14.277: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref =
0x000C
paar1#
Running
CallManager 4.2
MGCP
Gateway 2821
Bronze
Re: Long Distance
it seems to me that it may be an issue on the telco side. i think the 82 means its the telco switch so its reaching that but just cant seem to find the actual number after that.
id recommend that you speak to the provider but someone else may have some other suggestion.
hope this helps
Green
Re: Long Distance
I agree above, but also want to know if you are using NSF for this carrier in specific?
Re: Long Distance
No NSF is being used as far as I know. We are contacting our carrier and hopefully it is on there on end.
Thanks!
Re: Long Distance
Hmm.. It turned out to be the pattern itself, which is weird. It had to be changed from 9.1[2-9]XX[2-9]XXXXXX to 91.[2-9]XX[2-9]XXXXXX Discard Predot. Why would it differ since we are using the 9.1[2-9]XX[2-9]XXXXXX on our main site?
139
