longer than expected delays on outbound calls
All phones on-site are experiencing longer than expected times when calling out. Every call eventually gets out to its destination but takes alot longer than it should. - *note: calls used to talk alot less time
Running Cisco Call Manager 4.1
Gateway = Cisco 2801 using H323
Re: longer than expected delays on outbound calls
if u have have .T on the gateway dial peer
this will wait until inter digit timeout
which is about 10 seconds
in the case use more spesific dial peer
the same idea in CCM if u have a dial peer with !
if helpful Rate
Is this the .T you are referring to? (the 0T)
"dial-peer voice 100 pots
destination-pattern 0T
progress_ind alert enable 8
direct-inward-dial
port 0/1/0:15"
thanks
VIP Super Bronze
No,
That should not affect your calls. I have 9T on my h.323 gateway and I have no delays on the Calls...
You need to check your Route pattern and ensure that you are not using a wild card for the patterns...
Check that you have specific Route patterns for the called destinations
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
make it more spisific for example
092.....
this is considered more spsific
or let the user dial # after finish dialing
but make it more spesific better
even if u need to make more thank one dial-peer to cover all requeired distinations
good luck
if helpful Rate
Silver
You can reduce the interdigit timer per dial-peer
Timeouts interdigit x- x secs
181
