02-13-2007 04:43 AM - edited 03-14-2019 08:00 PM
I have a document to create and change phone ring tones in CCM 4.1
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_0/admin_gd/3_0_9/a3rings.htm
but in this document say me the correct format that ring tones would have to run properly in CCM and I need a program to do it. I don't know how I will do it.
Anybody can help me?.
Thanks.
Solved! Go to Solution.
02-13-2007 05:56 AM
You can use any program that lets you record and edit audio. Sound Recorder in Windows will do the job.
Hope this helps. If so, please rate the post.
Brandon
02-13-2007 05:56 AM
Brandon
