Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Looking for Cisco 7920 Config Util
Can someone please point me to where I can download the Cisco 7920 Configuration Utility as well as the Cisco 7920 USB Driver? I've looked all over cisco.com and I'm not finding it anywhere. Thank you for any help!
1 REPLY
Re: Looking for Cisco 7920 Config Util
http://tools.cisco.com/support/downloads/go/IPCheck.x?defAdv=N&sftAdv=Nℑ=Cisco-config-assistant-win-k9-1_6-en.exe&filepath=/swc/esd/02/crypto/3DES/268437893/guest&filename=Cisco-config-assistant-win-k9-1_6-en.exe&advUrl=null&isk=Y&defInd=N&mdfid=2780...
in case it breaks follow this path under the downloads:
Wireless > null > Configuration Assistant Software > 1.6 > Cisco-config-assistant-win-k9-1_6-en.exe
you can try this page when you don't find things:
http://www.cisco.com/pcgi-bin/swsrch/SWSearch.cgi
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1540
