Loop MoH - Enable music on hold multicast call quality issues
We have two CUCM 9.1 ( Pub / Sub ) servers run at two sites connected via a 1Gb layer 2 Ethernet link on VLAN 100.
When we enabled multicast for MOH on the subscriber to loop the music on hold when a call is placed on hold ( otherwise the moh file restart from the start from the begining each time the call has been placed on hold)  - we get call quality issues with external calls via the gateway.
We have Auto Qos enabled on all our swiches expect the gateways, as only being used with Voice.
What would be my best options to loop music on hold and not get call qaulity issues or how I troubleshoot this issue?
Not sure if there is a connection between the MoH quality issues and the music being played continuously.
I would start by making sure your MoH server is set in a region with codec G711 and your incoming VoIP dial peer to CM is set to G711 as well.
Hall of Fame Super Silver
Sounds like the port where the servers are connected are misconfigured (i.e. policy restricting voice bandwidth), can you post the config of the switch ports where the servers are connected with all relative config?
Chris
Hi Chris,
I've added the config for that server and gateway.
On the daul stacked 3750 - you have port Gi1/0/10 and Gi2/0/10 connected to CUMC 9.1 server and port  Gi1/0/12 and gi2/0/12 connected to the Cisco 2921 on port G0/0 and G0/1
Thanks again
I am sorry, what did you add?
Your server and GW ports should not have any policy defined on them, and should have "mls qos trust dscp" configured on the ports.
HTH, please rate all useful posts!
Chris
I've attached the config's in the discussion.
So these configurations below for ports are incorrect ?
Server Ports -
interface GigabitEthernet1/0/10
switchport access vlan 100
switchport mode access
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/10
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet2/0/12
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
interface GigabitEthernet1/0/12
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
Gateway Ports :
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
722
