Loosing BLF while moving IP phones inside the same VLAN
I was moving 40 phones inside the same VLAN. But 3 of them loose some BLF after the reboots.
I reset them. The user on it login and logout. But they doesn't reappeared.
Is there a known bug ?
I was using 7962 with 7915 extension with SCCP42.8-3-5S and extension mobility.
Call Manager version 6.1.2.1110-3
Best regards
Charles
1 REPLY
Re: Loosing BLF while moving IP phones inside the same VLAN
I had to do a dummy edit on the BLF page.
But I would like to avoid this kind of problem in the future.
Charles
317
