Losing leading digit
DigitalCindie
Hi All,
I've got a route pattern 1.04XXXXXXX which whenever a call uses this pattern it drops the 1. The discard digits choice is <None>
I have no idea where my 1 is going. It is set up just the same as one that keeps the 1. It did have the discard predot when I first put it in, but I have deleted the pattern and re-added it without ever turning on the discard predot. Could it still be 'remembering' and dropping the 1 because of that?
anyway, at a loss for ideas, so anything is appriciated.
Thanks in advance,
Here is the dialed number analyzer:
Results Summary
Calling Party Information
Calling Party = 7418
Partition =
Device CSS =
Line CSS = International_HM
AAR Group Name =
AARCSS =
Dialed Digits = 1041234567
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = 1.04XXXXXXX
Partition = National_HM
Time Schedule =
Called Party Number = 041234567
Time Zone = (GMT+12:00) Wellington, Auckland
End Device = RL_HM
Call Classification = OffNet
InterDigit Timeout = NO
Allow Device Override = Disabled
Outside Dial Tone = NO
Call Flow
Route Pattern :Pattern= 1.04XXXXXXX
Positional Match List = 041234567
DialPlan = North American Numbering Plan
Route Filter
Filter Name =
Filter Clause =
Require Forced Authorization Code = No
Authorization Level = 0
Require Client Matter Code = No
PreTransform Calling Party Number = 7418
PreTransform Called Party Number = 1041234567
Calling Party Transformations
External Phone Number Mask = YES
Calling Party Mask =
Prefix =
CallingLineId Presentation = Default
CallingName Presentation = Default
ConnectedParty Transformations
ConnectedLineId Presentation = Default
ConnectedName Presentation = Default
Called Party Transformations
Called Party Mask =
Discard Digits Instruction =
Prefix =
Called Number = 041234567
Route List :Route List Name= RL_HM
RouteGroup :RouteGroup Name= RG_HM
External Phone Number Mask = On
Prefix =
Called Party Mask =
Discard Digits Instructions =
Prefix =
Called Number = 1041234567
Device :Type= H323Gateway
End Device Name = 10.15.10.250
PortNumber = 0
Device Status = Unknown
AAR Group Name =
AAR Calling Search Space =
AAR Prefix Digits =
Inbound Fast Start = Disabled
Outbound Fast Start = Disabled
Tunneled Protocol = None
Calling Party Selection = Originator
Calling Party Presentation = Allowed
CallerID DN =
Alternate Matches
Note: Information Not Available
Oh ok
I would gather cucm traces to see its not a change notification problem in which DBreports certain configuration but current ccm process is using in its internal tables differnet information.
At some point there was a config in that specific route pattern that removes the digit?
You can delete pattern and see what you get now, or try to restart CCM service to re-red info from DB if config its ok.
5 Replies 5
gogasca
Level 10
Level 10
End Device = RL_HM
Do you have any digit modification at Route List level?
Check RL details
or at GW level?
oh, forgot to mention, CCM 4.1.
I couldn't see anything that would do it, but details below:
Route List details:
Use Calling Party's External Phone Number Mask - On
Calling Party Transform Mask
Prefix Digits (Outgoing Calls)
Discard Digits  < None >
Called Party Transform Mask
Prefix Digits (Outgoing Calls )
Gateway:
Device Pool*
Call Classification*
Media Resource Group List
Location
AAR Group  < None >
Tunneled Protocol   < None >
Signaling Port*  1720
Media Termination Point Required
Retry Video Call as Audio
Wait for Far End H.245 Terminal Capability Set
Path Replacement Support
Multilevel Precendence and Preemption (MLPP) Information
MLPP Domain (e.g., "0000FF")
MLPP Indication Not available on this device
MLPP Preemption Not available on this device
Call Routing Information
Inbound Calls
Significant Digits*  7
AAR Calling Search Space  < None >
Prefix DN
Redirecting Number IE Delivery - Inbound
Enable Inbound FastStart
Outbound Calls
Calling Party Selection*
Calling Party Presentation*
Called party IE number type unknown*
Calling party IE number type unknown*
Called Numbering Plan*
Calling Numbering Plan*
Caller ID DN
Display IE Delivery
Redirecting Number IE Delivery - Outbound
Enable Outbound FastStart
Oh ok
Yes there was, when I first put the route pattern in, it had discard predot. I set discard to None and it still dropped it. So I deleted and recreated the route pattern and it still dropped it. I will give the box a restart tonight and let you know if that makes any difference.
Edit: I have been doing test calls, not just the number analyzer.
Well I changed a few, and after the restart they are no longer dropping the 1 =)
Thanks for your help.
