Losing the CUCM
We have on several occasions lost power or network connectivity to a Gateway. Once power/network is restored, We did not reconnect with CUCM. We have to go into the gateway and type “no MGCP”, then MGCP.  At that point connections are complete. We have had this thru several different IOS Codes and ever since Call Manager 3.1.  We are now up to CUCM 8.6.  Any suggestions?
CSCtf46011 does not apply. As the Gzteway is Down, untill the No MGCP ...MGCP command is given.
Hi Pharden,Do you mean that
Hi Pharden,
Do you mean that the gateway is in the Unregistered state even after the power comes back?
What is the gateway model and IOS version that you are using?
I'd suggest taking a look at CSCtf46011.
Hantale
Sree
Yes, the voice gateway is
Yes, the voice gateway is down. Until you telnet in and do a No Mgcp.. then an MGCP
Please upgrade to 15.1(4)M8.
Please upgrade to 15.1(4)M8. This has the fix. What's the model of the gateway?
Gateways mostly 2921 and 2821
Gateways mostly 2921 and 2821. some 3845. We are using advance enterprise 12.4.20.YAB, which was recommended by TAC. but did not help.
15.1(4)M8 you say.... I will give it a try.
PHillip
hope this may help you. Bug
I think its a bug,
please find the link below along with the suggested resolution
https://tools.cisco.com/bugsearch/bug/CSCtf46011
Hope this help.
please rate,
thanks
Dennis
Yes, i reviewed this BUG.
Yes, i reviewed this BUG. Except the gateway Voice is down Hard.  Untill you telenet in and perform the "No MGCP"  .. Then MGCP
That is one of the issues
That is one of the issues that I have experienced with MGCP. I would suggest moving to H.323 or SIP if possible. Then you will not have to deal with MGCP problems like this.
Just my thoughts.
Please rate if this helps.
Thanks!
116
