Lost Call Manager Password any recovery utilities recomended
We have lost the administrator password to our Subscriber. The only options are password recovery utilities or a complete rebuid. Has anyone tried any password recovery tools on a 4.13 Call Manager and if so which one?
Hall of Fame Super Red
Re: Lost Call Manager Password any recovery utilities recomended
Hi Dushaune,
I have only used this in a Lab setting to change/recover passwords, but it worked like a charm :)
Check Password Synchronization with the Admin Utility in the Cisco CallManager Cluster
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml
Hope this helps!
Rob
PS: Make sure to run this after hours as it is service effecting!
Gold
The Administrator Password on the Publisher and Subscriber should be the same. Having the password for this account different is for sure going to cause more issues than anything else.
AdminUtility would reset the password and sync it, but only for all the Service account, but not for CallManager. I guess the only option here would be to use a Windows 2000 Password Recovery Tool (If any available). I've personally never had a chance to get/use any such tool
hi
and what about password recovery in CCM 5.x? is there any way/tool?
Gold
hi mchandak
i tried as stated in the iptplatform admin guide, i logged to
http://server-name/iptplatform
i used
Username: pwrecovery
Password: pwreset
but it gives Errors encountered,
Your username and password are not valid
can help pls?
thanks
Gold
What is the exact CM version ??
We are running CM Version 4.13
it is CCM 5.1
Gold
With Windows based CM, as I'd mentioned earlier, I'm not aware of any such tool being available. Please try to use a Windows Password recovery tool and see if that works. Else, the only option is to rebuild the box
Gold
I tried this on my server and it worked fine. Only thing is that I did a SSH to the Server and not Web. Can you SSH and see if this works for you or not.
hi mchandak
ok i SSHed to it:
login as: pwrecovry
pwrecovery@10.90.2.10's password:
Access denied
this is the output!
note that i used the pwreset password
Gold
Can you try this from the console of the server ??
484
