Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
lost Private password phrase for CallManager
Is there a way to find out the password phrase for Callmanager 4.1 3?
thanks
Allan
Gold
Re: lost Private password phrase for CallManager
You cannot find the Private Phrase, but can reset it by using Admin Utility (C:\Program Files\Cisco\bin\AdminUtility.exe) This file is can only be run on the Publisher and it would reset the Password Phrase along with the password of all the service accounts and restart these services. Therefore this tool should only be used during Off-Production Hours. Check http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml for information about how to use AdminUtility.
I know my private password phrase but when I running the setup for CRA 3.5(3) the attached message appear.
note that:
I pursued all the setup in the admin utility.exe
Bronze
Hi, sorry by this, is your installation in a co-resident server?
Can you ping to the CCM hostname?
Best regards
David
NO I ping the CCM IP address only
I am trying to ping the CCM hostname but I get this (unknown host CCM1)and by IP address it is ok.
what shall I do?
Add the CCM hostname to the lmhosts file on the CRA server. You can find it in C:\Windows\System32\Drivers\Etc\Hosts
Be sure to remove the .sam extension from the file once you populate it.
thanks a lot for your quick response and support
how can I create user name and password to access CRA 3.5(3) web application (http://x.x.x.x/CRALogin/AppAdminLogin)
Bronze
Hi, the default username and password during the first-time setup process only are: Administrator/ciscocisco
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_3_5/installation/for_crs_getting_started/gs35.pdf
Hope this help
David
thanks for your quick support
done
dears, oe more thing, I am planning to upgrade to IPIVR V 4.0 from 3.5(3), already we have 900 IVR port license, my question is: can I use this license when upgraded to V 4.0.
CRA engine not start
Bronze
Hi,if "CRA does not start" check this troubleshooting guide.
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/prod_troubleshooting_guide_chapter09186a0080193f35.html#39037
Best regards
David
CRA engine still not start
241
