Lost softbutton features 7965
I have lost softbutton features ( Conference ) on a 7965.  Is there a way to upload the TFTP file to just that phone or is there another way to fix this issue?
1 ACCEPTED SOLUTION
The "conference" softkey is assigned by default. Try assiging the "Standard Softkey" template to the phone and reset the phone.
Yosh
HTH Regards, Yosh
Did you verify the "Softkey Template" assigned to the phone?
Yosh
HTH Regards, Yosh
Hmm there is not one assigned.  But it seems all the phones here do not have a template assigned either
Yosh
HTH Regards, Yosh
That seemed to have worked!  Thank you!
You're welcome.
Yosh
HTH Regards, Yosh
84
