Community Member
Lotus Sametime 8.5.2 Integration with CUCM 7.1.3 and CUC 8.0.2
Hi all,
Has anyone done any type of integration between Lotus Sametime and CUCM/CUC ? I've got a Cisco IPTel environment running CUCM 7.1.3b SU2, Unity Connection 8.0.2 and a Lotus Sametime environment running version 8.5.2. I am looking into to see if there is any way to integrate the two environments, leveraging some of the telephony features that came with Sametime.
Any documentations / inputs / suggestions is highly appreciated !!!
Thanks in advance !!!
D.
1 ACCEPTED SOLUTION
Community Member
Re: Lotus Sametime 8.5.2 Integration with CUCM 7.1.3 and CUC 8.0
You could integrate your sametime client with Unity Connection for voicemail notification and management
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd8067a2ab.html
Cisco:
"Cisco Unified Messaging with IBM Lotus Sametime is  available free of charge to customers who already have a Cisco Unity or  Cisco Unity Connection system deployed using Internet Mail Access  Protocol (IMAP) for Microsoft Exchange or IBM Lotus Domino. The software  can be downloaded from the Cisco Software Center at: http://www.cisco.com/public/sw-center/. Simply select "Cisco Unified Communications Plug-ins with IBM Lotus Sametime" to access the downloadable file."
Community Member
Cisco:
Community Member
Thanks Robert ! I appreciate your help !!!
D.
Silver
There is also a Smetime "click-to-call" plug-in that uses a SIP trunk to CUCM and is normally used with Presence, but might be of use even without the Presence server.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucibmlotus/cpcap/7x/english/integration/guide/cpcapig70.html
HTH,
Art
1171
