Community Member
Low available virtual memmory on CallManager
Please find the attached screen shot from RTMT .Do i need to upgrade this callmanager from mcs 7835 to mcs 7845
1 ACCEPTED SOLUTION
Community Member
Re: Low available virtual memmory on CallManager
1gb is below the required amount, you need 2gb minimum. Yes its just a straight foward RAM upgrade. You just need to ascertain the correct type from your server model. A 7835 is basically a HP DL380.
Community Member
WHat version of CCM are you running? I assume V4.x.
If yes, do have the recommended minimum 2gb RAM? This sounds more like a memory issue, which shouldn't require an upgrade from 7835 to 7845!
Community Member
CCM Version 4.1 (3)
Yes,We have only 1 GB ram installed.
So,I should upgrade it to 2 GB .
Is it simple as any other desktop ram upgradation..i doubts..no problem will occure at upgradation of RAM..
thanks a lot
Community Member
Community Member
Thanks a lot .
After you add your new RAM in to 2gib, change your Pagefile to a min of 2gig.
192
