Low volume external calls incoming
Alistair Pidd
I have a issue with low volume external calls coming in. The calls are delivered to the company via an ip ip gateway from the service provider(H323 to H323). The ip phones are then located across WAN links at remote sites.
Only 2 out of approximately 10 sites are affected (but its difficult to assess as externals callers have to alert the called user). The handsets as these two sites are different but are 7911 at one and 7912 at the other. Additionally LAN to LAN calls are not affected within the network.
The issue seems to be more of an issue related to the PSTN, which is obviously located within the provider network. The service provider has claimed to have checked this and found nothing wrong.
Does anyone have any ideas how to prove that the issue is located in the SP network or even better had and resolved the issue otherwise?
charafchajii
Can you send me the configuation of the IpToIP gateway ?
Here is the IP IP Gateway (H323 into the provider currently)
service password-encryption
boot-start-marker
boot system flash c3825-ipvoice_ivs-mz.124-11.T4.bin
boot-end-marker
logging buffered 9999
no logging console
no aaa new-model
network-clock-participate slot 1
ip cef
no ip domain lookup
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
voice rtp send-recv
voice service voip
h323
emptycapability
h225 h245-address on-connect
h225 connect-passthru
h245 passthru tcsnonstd-passthru
voice class h323 2
h225 timeout tcp establish 3
translation-rule 1
Rule 1 90 0
Rule 2 91 1
Rule 3 92 2
Rule 4 93 3
Rule 5 94 4
Rule 6 95 5
Rule 7 96 6
Rule 8 97 7
Rule 9 98 8
Rule 10 99 9
translation-rule 2
Rule 1 ^1 901
Rule 2 ^2 902
Rule 3 ^3 903
Rule 4 ^4 904
Rule 5 ^5 905
Rule 6 ^6 906
Rule 7 ^7 907
Rule 8 ^8 908
Rule 9 ^9 909
interface GigabitEthernet0/0
ip address 172.31.203.7 255.255.255.224
duplex auto
speed auto
media-type rj45
no keepalive
interface GigabitEthernet0/1
ip address 10.0.220.33 255.255.255.248
duplex full
speed auto
media-type rj45
no keepalive
ip route 0.0.0.0 0.0.0.0 172.31.203.3
ip route 0.0.0.0 0.0.0.0 172.31.203.5 200
no ip http server
access-list 10 permit 172.31.203.250
access-list 10 permit 172.31.203.254
access-list 10 permit 172.16.0.48
access-list 101 permit udp any any dscp ef
access-list 101 permit udp any any range 16384 32768
access-list 101 permit ip any any
access-list 102 permit udp host 172.18.38.101 any dscp ef
access-list 102 permit udp any any range 16384 32768
access-list 102 permit ip any any
access-list 103 permit udp any host 172.18.38.101 dscp ef
access-list 103 permit ip any any
control-plane
sccp local GigabitEthernet0/0
sccp ccm 172.31.203.38 identifier 1 version 4.1
sccp ccm 172.31.203.37 identifier 2 version 4.1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 3 register MTP0019567ea480
dspfarm profile 3 mtp
codec g729r8
maximum sessions software 96
associate application SCCP
dial-peer voice 200 voip
description Subscriber
preference 1
destination-pattern .T
translate-outgoing calling 2
voice-class h323 2
session target ipv4:172.29.2.2
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 201 voip
description Publisher
preference 2
voice-class h323 2
session target ipv4:172.29.2.3
no vad
dial-peer voice 100 voip
tone ringback alert-no-PI
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
translate-outgoing called 1
voice-class h323 2
session target ipv4:10.0.1.1
no vad
gateway
timer receive-rtp 1200
gatekeeper
shutdown
line con 0
login local
line aux 0
line vty 0 4
exec-timeout 3600 0
privilege level 15
password
login local
line vty 5 15
privilege level 15
password
login local
scheduler allocate 20000 1000
end
Hi, did you guys get this resolved. I have the same issue as well.
Yes this turned out to be firmware related. Both the 7911 and 7912's were affected. There is a noticable difference in volume (not related to the configurable volume) of calls when the firmwares are upgraded to the lastest issue from Cisco. You can tell if its this issue because it you put the call on hold and get MOH, the volume gets normal/loud again.
