Community Member
LSC Authentication 7965
Greetings All,
LSC installed successfully on my IP PHone 7965, how do i change the settings of authentication mode from username and password to LSC Certificate authentication on IP Phone 7965. i can connect successully to VPN using username and password everytime when it reboots it keep asking for the username and password. Please i need help, all help appriciated. Thanks
webvpn gateway remotephone
ip address 192.168.0.100 port 443
ssl trustpoint pbx_cert
inservice
webvpn install svc flash:/webvpn/anyconnect-win-3.1.05152-k9.pkg sequence 1
webvpn context remotephone
ssl encryption 3des-sha1 aes-sha1
ssl authenticate verify all
policy group remotephone
   functions svc-enabled
   functions svc-required
   hide-url-bar
   svc address-pool "remotephone" netmask 255.255.255.0
   svc default-domain "pbx.com"
   svc rekey method new-tunnel
   svc split include 192.168.0.100 255.255.255.255
   svc dtls
virtual-template 1
default-group-policy remotephone
gateway remotephone domain remotephone
max-users 100
authentication certificate
ca trustpoint pbx_cert
inservice
ephone  8
device-security-mode authenticated
capf-auth-str 8121
mac-address DCA5.F487.2C26
type 7965
capf-ip-in-cnf
vpn-group 1
vpn-profile 1
button  1:8
Everyone's tags (3)
Hi Syed,
You can change the 'Client Authentication Method' to Certificate based under VPN Profile setting on CUCM page. Please check the following link
https://supportforums.cisco.com/docs/DOC-21469
Let us know if it helps.
Manish
Community Member
Hi Manish,
Thanks for the reply but i'm using call manager epress 8.6 on cisco 2851. Please letme know if you have any suggestions  are even the document to refer i greatly appriciate your help. Thanks
Hi Syed,
You can configure certificate based authentication on CME as per the following link for CME administration guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevpn.html
Manish
Community Member
Hi Manish,
Once again thanks for the reply i did went through that documents prior posting my issue its does not really expalin what im looking for. Thanks
205
