LSIESG_AlertIndication / LSIESG_DiskDrive_Modified
Hi all,
Does anyone know what the following alert means and it severity? I'm running CUCM 8.5.1
hwStringMatch : Jun 1 20:29:37 SUB01daemon 4 Director Agent: LSIESG_AlertIndication 500605B003561070 Predictive failure: PD 02(e0xfc/s2) Sev: 3.
AppID : Cisco Syslog Agent
ClusterID :
NodeID : SUB01
hwStringMatch : Jun 1 20:29:37 SUB01daemon 4 Director Agent: LSIESG_DiskDrive_Modified 500605B003561070 Predictive failure: PD 02(e0xfc/s2) Sev: 3.
Any help will be really appreciated
Aaron Harrison
It means one of your disk drives has failed a self test or crossed an error threshold and thinks it might fail soon.
You should get it swapped out. I'm not sure which disk it's referring to, there are tools available for further diagnosis (like this http://hwraid.le-vert.net/wiki/LSIMegaRAIDSAS) but you'd need root access so you'd be best to contact TAC to determine which disk it is and get it swapped.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
Hi all,
TAC Case opened, Hard disk replacement is underway. After the change I will post the results.
nikshah
Hi Guilherme,
Can you ssh to the server you are having this issue and run the following command
show hardware
Also in your server room do you see any LED's blinking /flickering on the front where you have the HDD or on the motherboard.
