<Urgent> BAT VG224 DN issue !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hi, anyone who can give me a Export txt file for adding VG224 DN or how to BAT this goal.
I have add 10 VG224 into CCM (5.1), now I need to add some DN on VG224 through BAT, but i always failed though I have tried many way .
Could u pls give me some help? or share me the TXT.
Urgent!!!
1 ACCEPTED SOLUTION
Re: <Urgent> BAT VG224 DN issue !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Only thing to do avoid doing it all manually is to upgrade to 6. Make sure you go to 6.1.2 though, as there are a number of annoying bugs with VG224/BAT in 6.1.1
Cheers,
Alistair
i think its suported on V6 not 5 !
I don't believe the BAT import of VG224 DN's is supported on 5 or 6 to be honest (248's are), it sounds like it's going to be a painfully slow manual process.
Hall of Fame Super Red
Hi Zhang,
Marwan is most correct (nice!)+ 5 points for this Marwan :)
This is not supported in "older" CCM Versions;
CSCeg88823
Symptom:
BAT does not support adding VG224 ports in bulk
Conditions:
This is for all versions of BAT and all current version of Callmanager 3.x, 4.x, 5.x
It is now supported in CCM 6.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/t08gwins.html#wp1345635
Hope this helps!
Rob
thanks rob :) and 5 from me for the detailed info as well
Thanks all, each one 5 points.
My god, how can i handle this so many fax manually??????
Cheers,
Alistair
226
