07-08-2009 07:46 AM - edited 03-15-2019 06:52 PM
I need the MAC address to upload some license files. I am using PUTTY and SSH to get into the Linux Box. What command do I use to get this info. I have tried the Show Network commands with not any luck. Can any one shed some light on what I need to use to get the MAC?
Thank You
07-08-2009 07:54 AM
show tech network interfaces
This will give you the MAC address of the server. You can also view it using the OS Administration GUI: Show->Network
Adam
Please rate if helpful
07-08-2009 08:05 AM
Thank You that is exactly what I needed
