Mailbox usage in unity connection 7
I would like to know how to get a single report/web page that shows the current per mailbox usage on my unity connection 7. I know that I can get that information for a specific mailbox, but it would be handy to get that info for every one of them.
Thanks.
1 REPLY
Hall of Fame Super Red
Re: Mailbox usage in unity connection 7
Hi Francois,
There is a perfect tool for this type of report. We have used this during our rollout to search for the same info.
**I don't believe any of the "built-in" CUC Reports will show this info
Connection User Data Dump (CUDD) Tool
The Connection User Data Dump (CUDD) is a Windows-based remote database administration tool available on the Cisco Unity Tools website. CUDD allows you to export specific information about users to a file that can be viewed or imported into another application, such as a database utility or Microsoft Excel. When the data is exported, the tool automatically creates a header row that lists the data type found in each column of the output, for ease of import into other programs.
The tool is available from the "Superb" Unity Tools site;
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/UserDataDump.html
From the Help Notes;
Requirements/Special Notes
This version of User Data Dump runs on Windows XP/2000/2003 or Vista.
***This version of User Data Dump only works with Unity Connection 7.0(1) or later.
You must enable the ODBC proxy service on the Unity Connection server and attach to the database using an account enabled for the remote database access role. See the next section for details on this.
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm
Hope this helps!
Rob
304
