Make new call on busy shared line
I have some users that share a line, besides their primary extension.  One user was on the shared line and the other user wanted to make a new call from the shared line.  When the 2nd user picks up the shared line she barges into the 1st users call.  So how would she make a new call on the shared line without disurbing the existing call?
Hi Anthony.
Please start mention what version of CUCM/CME are you running.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
CUCM 8.5.1
Hi Anthony.
Usually a second call from a shared line is allowed and user should not be able to join an active call on a shared line.
What kind of device are sharing line and whic protocol are they running?
Carlo
Also put privacy to "on" on all IP Phone sharing the line or globally though service parameter confiugration
Carlo
Hall of Fame Super Red
Hi Anthony,
In addition to the good tips from my friend Carlo (+5 "C")
You will also want to check the "Max Calls" setting on each of the
shared line DN pages in CUCM admin. This may need to be set to
a higher number.
Cheers!
Rob
"Why do the best things always disappear "
- The Band
I know this is a strange request, but most of the time the want listen in on the shared line.  So turning privacy on would eliminate that requirement.  Picture it like adding a button with a second apperance of the shared line ( but i can't because I'm out of buttons ).
Sorry, actually its simple.  Just hit the "new call" button and select the line you want to use.  Duh, I feel stupid.
Thank you everyone for helping me work through this.
117
