Make use of another CCM translation pattern
I have 2 CCM cluster in 2 location (site A & B).
Site A setup translation pattern to route the call. In Site B, I want to make use of the Site A translation pattern instead of re-create it in Site B CCM.
How can it be done? The trunk between 2 sites are working fine. However, I just got no way after some trials.
Tkx
Everyone's tags (1)
Since they are two diifrent clusters then there is no way to replicate the config between them
Each cluster has it's own call routing and dial plan config
And you need to setup things per cluster as desired
Hope this help
If helpful rate
Re: Make use of another CCM translation pattern
Even though you rated this post as not helpful but what I mentioned is a fact you need to be aware of !!
Hi, first, thank you for your answer.
However, i really believe there should be a way to make use of other CCM translation pattern. I have 3 CCM cluster world wide. I really don't want to add the route pattern by mannual for the same stuff even I as a CCNP Voice with 5 years hand-in experience on CUCM. I cannot also find it out from Cisco Manual or some text book.......
Other than sending the calls to the other cluster so that you use that translation pattern (and whatever pattern/behavior you have configured there) there is no way to use something that is not local to the CUCM DB to do call processing.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
As java stated above the concept is all about DB each cluster has DB publisher to write to the cluster database and subscribers to receive the updated info for call processing and other functions
Another cluster means completely different DB cluster and there is no way at this time to replicate config/DB data between different clusters
Hope this help
For your info
If younhave multiple CUCM clusters and you want to centrelize the dial plan to some extent you can use cisco season manager edition of CUCM deign for this type of solutions
http://docwiki.cisco.com/wiki/Unified_Communications_Manager_-_Session_Manager_Edition
i tried to send the call to the 2nd CCM. However, it is failed to use that translation pattern. Can you please give me something in detail so that i can try it by myself?
433
