Making a call by restriction codes on CCME
mdom
?Can I forced to use an account codes in a CCME v4.0 and Call Detail Record (CDR) field entry to make a call?
9 Replies 9
paolo bevilacqua
Yes CCME supports Account so I guess it would copy that into CDR.
It mean that the CCME 4.0 can be configured with restrictions code for each user. An another words, ?can I confiure some users can make a international calls and other not be done?
Sure, you have three methods:
1 - COR list. you permanently block certain calls from certain phones
2 - PIN login & afterhours. Once logged with a per-phone pin in you can dial certain patters and also define a time schedule for this to happen.
3 - Custom steering digits. You create special prefixes to allow certain calls and this code is given to ppl kind of like an account number.
1 & 2 are explained in the sysadm guide and others CCO documents. 3 - is not but easy to figure out.
hey check this out. simple and as stated before, you will be using this FAC and COR lists to allow or disallow users. the readme is very detailed
Note: have not personally installed or tested
Thanks so much, I?ll check the file and we?ll make the test with our lab equipments.
Manuel Dominguez
Dear sir
i tried to use it in new IOS that used application--> service FAC --> tftp://x.x.x.x/fac.tcl and define min-uid and define this service under dial-peer but it did not work with CME 4.0(3)
thank you
kindest Reagards
Please include your dial-peer and service configuration.
hello
this is confgiguration
tftp-serve flash:FAC/acctfixedpin.tcl
application-->Service FAC tftp://x.x.x.x/FAC/acctfixedpin.tcl
param uid-len 5
then go to dial-peer that need FAC
dial-peer voice 7 pots
service FAC
destination-pattern 905.......
corlist outgoing FAC-required
port 0/1/0
dial-peer cor custom
name All-users
name FAC
dial-peer cor list Users
member All-users
dial-peer cor list FAC-required
member FAC
That doesn't work because "service" configuration works for inbound DP only.
To make so the IP phones can reach the FAC service, you need to configure a voip DP in "loopback mode":
dial-peer voice 77 voip
service FAC
incoming called-number 905.......
session target ipv4:10.1.2.3 <--- PUT ROUTER ADDRESS HERE, PREFERABLY LOOPBACK INTERFACE
codec g711ulaw
dtmf-relay rtp-nte
no vad
