Making a Voip a "Hot Phone"
     Is there a way to be able to pick up a Voip and have it automatically call 4 + numbers at once and allow the other ends to answer and have a conference call.
Re: Making a Voip a "Hot Phone"
Hello Davion
What kind of phone you have? An analog Phone or an IP Phone?
Do you use CME or CUCM?
Is the station you want to originate the call from an IP phone or an analog station?
You can use PLAR.
Hall of Fame Super Silver
This question has been asked many time on this forum, simply search for "hotline", "PLAR", etc and you  will find many great, in depth answers.
HTH,
Chris
A PLAR?? sure, as Chris mentioned just take a couple of minutes to search and you'll find the instructions
However only if you're calling into a meet-me you'll be able to get the conference.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
403
