Making TFTP dedicated in a CUCM 8.5 cluster vs ITL files
I've a question:
When adding a new CUCM Subsciber TFTP dedicated into a 8.5 cluster, do I need to do somethinh with ITL files?
If Yes, how?
Or is following chapter "Add a New Node to an Existing Cluster" from the Installing Cisco Unified Communications Manager Release 8.5 guide enough?
Looking forward to see your reaction.
rg
Remco
1 ACCEPTED SOLUTION
No, the new node will be
No, the new node will be included in the ITL and will be trusted.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Ok, thnx!!rgRemco
Ok, thnx!!
rg
Remco
86
