Manage scripts with CUC 9
I want to configure a Queuing with CCM 9, I know that this is with a Hunt Pilot and as destination pattern put the trigger to CCX and launch the scripts, but in my case customer does not have a CCX, only CCM 9 with CUC9, so how can I manage the scrips into the CUC9?
Into CCM in hunt pilot i can manage calls when are busy, no answer and so on, but want to manage scripts made with Editor into the CUC9, I know that this is possible but i dont know exactly how to do it, does anybody made it??
Thanks!
6 ACCEPTED SOLUTIONS
Hi Ivan.
Create a new call handler called eg. Transfer.
In transfer rule -->standard. select Extension as transfer action and put 1500 in the extension field
On your call handler go to greetings--->>standard
In "after greeting" section select "call handler" and select the previously created call handler "transfer"
Try it and let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Ivan.
To achieve this, create a CTI Route Point with a DN where you'll forward busy calls from HP.
In Call handler configuration select greetings.
Select Standard
in after greeting action select "take a message.
As standard greeting, record your own prompt say "all agents are busy at the moment"
For Scheduler...
-Go to Call handler
-select one active schedule and click view
-Create a new schedule by clicking "Schedule on top left" and "New Schedule"
-Enter the name of new schedule a leave "holiday schedule" to "none"
-On Schedule detail section click add new
-Enter a name and select 00:00 as start time and 23:59 as end time.
-Then select "Active Saturday and Sunday"
Save
Go to call handler and select this schedule as active schedule.
Carlo
Hi Ivan.
If you want to send a call hitting all agents busy or with no answer you have to create a new RP with a new DN forwarding all calls to VM.
Configure the follwing parameters in HP configuration page (substituting 9100 with the DN of the new RP
Regarding the scheduler, you have selected Sunday and Saturday as active days... in this case the only working greeting is "closed" that should be activated.
Carlo
Hi Ivan.
Go to call handler -->> Edit-->> Message settings
Here you specify message length.
Uncheck "Caller can edit message"  this avoid to ask user to press #
Also specify recipient (this is the voice mailbox where the message will be stored)
Carlo
Hi Ivan.
You said:
2- Queuing , in transfer to VM, now transfer but play a prompt "the operator is not available" as this is a RP who send to VM where can i change to a personal prompt? and where will i hear the messages?
As I mentioned you have to create a new call handler with the same DN of the recently created CTI route point.
Here you have to modifiy Standard Greeting with a personal recording.
Carlo
Hi Ivan.
Please attach the following screenshot:
-Call Handler 4020
-Standard greeting configuration captured from System Call handler -->>(call handler with 4020)--->>edit--->>greetings--->>Standard greeting.
When you call an ip phone which has a directory number forwarded to VM , Unity Conn will present the greeting of user's VM.
When you call a DN forwarded to another DN which is forwarded to VM  you will hear original called DN's VM if it has one configured otherwise you'll hear the system prompt.
To avoid this behaviour, you should change redirect settings in Unity connection going to advanced --> conversation -->> and check the "Use Last (Rather than First) Redirecting Number for Routing Incoming Call" Option-
Carlo
VIP Super Bronze
You cant have scripts edited by uccx script editor in CUC. Its not possible. I dont know who or where you heard that from, but thats certainly not true. If you need the functionality provided by UCCX, then you need to purchase UCCX.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Thanks for your reply,
I will investige this point because may be is not possible, may be this issue is with call management or something else.
if i found something to do it i will say you.
Regards.
Hi again.
After look for information about the issue about scripts in CUC, i was mistake, what i wanted is manage prompts, not scripts.
About this i have a question, I want that somebody who call from PSTN route the call to CUC, play a prompt and ask for options, after this options route the call to a Hunt pilot, i make this:
TP 3999(or a PSTN number)  to called 4000  ---> RP 4000 with CFA to VM ----> System call handler 4000 with prompts of wellcome, and option # to forward to Hunt pilot ----> all agents logged into Extension Mob can answer call, and if nobody answer transfer to VM
My problems:
1-when I call 3999 route the call fine to VM and play prompt of Customer but before this prompt put a unity promt, i am not able to avoid this unity prompt
2-In Hunt Pilot, Queuing option i put as destinattion patter a TP 4000 with CFA to VM and play prompt of "all agents are busy" but dont forward this call with the destinattion pattern, and play before the unity prompt of "sorry"
If I call directly with a CIPC to 4000 play this promt fine, but not from Queuing.(before the sorry prompt of unity too)
Any idea how to avoid hear the unity prompt before my wav recorded?
And why if a call to TP 4000 with a CFA to VM i hear fine the prompt but from queuing fail?
Thanks!!
Hi Ivan.
If you defined a system call handler, just selecting  "my personal recoring" as standard greeting you shouldn't hear any system prompt.
Why don't you call directly 4000 instead of 3999?
What do you mean, "From queuing"?
Let me know
Carlo
Hi Carlo
1- In CUC in Standard Greeting > Callers Hear > My personal Recording, is already checked,but still i hear when call to 3999 "sorry" "is not available......" and after press # transfer call to Hunt pilot, but it does not do it automatically.
2- In CUCM9 > hunt pilot > queueing there is an option to transfer calls in the case no user be logged, i put transfer to a RP with a DN of the VM in CFA but dont go there, goes to VM unity.
About your question i dont call directly to 4000 because is a test when calls came from PSTN.
1 That's because you failed to record the greeting, as a greeting, and recorded it as a recorded name.
2.
"i put transfer to a RP with a DN of the VM in CFA but dont go there, goes to VM unity."
That's not clear at all, so you want it to go to CUC or not???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime
1- Thanks now play only greetings prompt, perfect, but after it should transfer automatically to extension 1500 which is a Hunt pilot, but only play the prompt in a loop.
2- you are right i will explain myself better, in CUCM after rings in all agents logged, if nobody answer the call should send the call to VM , play a prompt of "all agents are busy, please leave a message" , but dont forward there the call, the call go to the system prompt of unity and hear Unity prompt.
Thanks!!
Hi Ivan.
Carlo
Hi again !!
After last post from Carlo now is transfering perfectly after first prompt to the HP 1500, thanks!! but for finish i have 2 problems now
1- When all agents in the HP are busy the call must to be transfered to CUC again and prompt "all agents are busy, please leave a message....."
In CUCM > Hunt pilot > Queuing I put transfer to DN 4020 which is a Call handler, this have a Transfer rule to user with voicemail for leaving messages, and fails.
I tried to transfer directly to a user with mailbox but fails, do not transfer, drop the call
Finally i tried to transfer to a DN with a CFA to CUC, this runs but play a prompt "the operator is not available" ????
How can i transfer from queuing to a VM , play prompt and leave a message??
2 - The other problem is trying to configue the schedule in CUC, i configure one for only weekend to test it, i added it in the call handler > Active schedule -> weekend , with only for saturdays and sundays, but fails, why?
Thanks!!!!!!!!
Hi Ivan.
Select Standard
For Scheduler...
-Go to Call handler
Save
Carlo
Hi Carlo,
I created a CTIRP called 4020 with a DN 4020 with CFA to HP 1500 busy calls.
In the HP in queuing > transfer > I put 4020, when i call to Translattion Patterrn, calls to CUC....after greeting call to HP ...all phones and after it, calls again to all phones and finally drop calls, so is not running
About schedule stills fails with your steps, i create a schedule for weekends as i show u below but when i call to TP runs as always
sorry, but is not working
Thanks!!
Hi Ivan.
Carlo
Hi!!
Well we inching jejejej, about my two problems i am in this point:
1- schedule, now is working!! just clicking in close standard, ok!! only question about this, after greeting, and prompt i can leave a message, but where? how can i hear those messages?
Thanks again!!!!
Hi!
one doubt about schedule, after i hear "all agents are busy...." while i am leaving a message , after 2 o 3 seconds, system cut and say "to leave this message press # or hang up" , so, how can i make to have more time to leave a message and how can i leave a mesage without press any key?
In greeting closed > after greeting > call action > is "take message" but i dont see how to put more time, nor how to send a message without press anything.
thanks!
Hi Ivan.
Carlo
Hi Ivan.
Carlo
Hi Carlo
In the issue about transfer to VM still say "the operator ...." I have a Call handler with my personal prompt but it does not run, see pictures below please with the configuration of HP, ctiRP with DN and Call Handler
And i recorded my personal greetings in edit greetings, but sayd "operator...." where is the error? i can not see it.
About leave a message in message settings I uncheck the "caller can..." but is the same, wait a few seconds and play system prompt of press #
With your steps should run properly but not.
Thanks!!
Its a weird behavior, if I put in a phone a CFA to VM, when i call to that phone, the call go to VM and play my personal prompts....perfect
But if i put in queuing that phone, without change anything and call to TP - > CUC -> HP  -> transfer to that phone play a system prompt, when is the same phone ¿??
so, in summed up, if the call came from queuing goes to "the operator is not available..." and when i call directly to that phone goes to his own VM ,why?
Thanks!
Hi Ivan.
-Call Handler 4020
Carlo
hi Carlo!
Let´s see now almost all is working fine, but with some details, for example after review all steps you send me yesterday, now when all agents are busy send call to VM!!
This have a VM which i can hear messages, perfect.
There are some details i need to resolve.
1- After send call to VM and hear "all agents are busy....leave a message pressing # " system still play it prompt.so  after changing in edit messages the maximun message length, only let me a few seconds and play the system prompt.
2- if the call goes to VM because no agents are available, while client is wainting if any agents is available in that moment how can i do to send the call to him again?
This should be more or less as a CC.
I think the rest is running fine, thanks and thanks again
Queuing is working fine, only need to know how to configure when the call goes to VM how to avoid the system prompt "press # to leave a message" because after my personal recording always play that prompt, even checking only "my personal recording"
And how to put more time to leave a message, in edit message i change it but dont take the changes.
thanks.
524
