Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Manager/assistant’s extension
Dear Team,
users will call out and their own extension will be displayed (e.g. Brendan Law, ext 200 will have caller ID 02-4960200) but when a call is returned to that number, it will go to an assistant’s extension (e.g. Judith Jordan, ext 101 for Brendan’s calls).But internal call should go directly to Brendan.
Please advise the solution?
1 ACCEPTED SOLUTION
HiIn this case you can create
In this case you can create a new partition and put there the translation pattern.
Than create a new CSS  to add to Incoming CSS on Gateway configuration page where you will add only partitions that let VG to reach desired Internal Extensions. In this newly created CSS add also the new partition containing the translation pattern.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.You can configure  a
Hi.
You can configure  a translation pattern such as:
Pattern:024960200
Called party transform mask: 101
This will route incoming calls from piston to assistant extension, while internal will route normally.
Carlo
Please find the attached
Please find the attached snaps.I have try this option but did not worked.
Hi.Please change the calling
Hi.
Please change the calling search space value to something that can reach the destinstion extension and it should work
Carlo
Yes i change to the national
Yes i change to the national CSS but still not working.
Note: 3 digit also coming from the gateway .
Ok.In this case in
Ok.
In this case in "translation Pattern" field you should put digits that you receive from VG.
Let me know
Carlo
Actually on voice gateway 4
Actually on voice gateway 4 digits are landing , but  from CUCM gateway page,we allow 3 digit and also the internaly using 3 digits.
I tried to create with 200 translation pattern but i didt work.
HiWhen you call 024960200
When you call 024960200 from PSNT, which number is sent to CUCM from VG
Please let me know
Carlo
0200 From VG to CUCM
Ok.So in this case, in
Ok.
So in this case, in Translation Pattern field, put 0200 and 101 as called party transform mask.
Remember tu put the right CSS in Translation Pattern in order to allow the call to reach 101 extension.
Carlo
From CUCM gateway page,I have
From CUCM gateway page,I have selected 3 digit , so three digit are coming . I change the partion on  ext 200 from internal to none and then creat traslation pattern of 101 with internal partition.Now incoming call from PSTN is landing on 101 but internal call is also landing on 101.
Carlo
Its solve the issue . Thanks
Thanks you so much
You're most welcome and
You're most welcome and thanks you for the nice rating
Cheers
Carlo
101
