Manager/PA phone set up
Hi All,
I need to set up a solution for our 3 PA's in the Director's corridor to be able to:
Intercept calls for the directors and then transfer them to the Director
See when the Directors are on the phone
See when a particular phone is ringing
The Directors all have 7942's and the PA's have 7962's
There are 6 Directors and 3 PA's. Each PA is set to personally manage 2 Directors each, but also needs the ability to manage the other 4 when the other PA's are away or busy.
Any ideas?
Thanks for reading
Hall of Fame Super Red
Hi Charles,
What are you running for call control? CUCM or CME?
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
When you say intercept calls: Do you mean intercepy EVERY call, or just intercept most calls ?
GTG
Please rate all helpful posts.
Hi Rob - I am using CUCM
Hi Gordon - I would say most calls. As each PA is directly responsible for 2 Directors they can't control every call, so they ofer a "best effort" kind of service.
I've updated the setup today by creating secondary numbers for each Director and adding the Directors' main numbers back to the PA's 7962s, so when a PA intercepts a call they can transfer that call to the secondary number, which works well. They can see which Director is receiving a call and I can set the alert type for each Director.
But the main PA is still moaning that it's different form the "single call ringing button" Nortel feature and that she shouldn't have to remember 2 numbers for the Directors (secondary numbers range from 111 to 116 !!)
I've told her the system now is temporary, which she believes, but she still wants a simpler system, if possible.
The way we setup similar things is to have two buttons per Manager. The first has a shared line apperance of the Manager (so the PA can pickup the call) and the second is a BLF SD button, so the PA can put the call back. Unfortunately for you, this would require you to get sidecars & power bricks for all your PAs.
I agree with you, though, that CUCM's abilities in this aren't as good as traditional phone systems. I think it's because CUCM is trying to be too flexible & clever.
GTG
Hi Charles,
You have a number of options here that may be helpful. You could use;
Cisco Unified Communications Manager Assistant With Proxy Line Support
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fsipma.html#wpxref25292
Or perhaps Busy Lamp with pickup;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fscpickg.html#wp1094928
Or you could set up Intercom so if the PA answers the call they can put it on hold and contact the Director;
https://supportforums.cisco.com/docs/DOC-4194
I'm curious what the Nortel did that the PA liked so much?? I've worked with Nortel for many years
and haven't found many things that it did that CUCM can't Single call Ringing (SCR - xxxx) doesn't
allow you to transfer back to the Director number so I'm not sure what she is missing.
Cheers!
Rob
Rob,
Where's this "Auto Call Pickup" option, mentioned in that CUCM manual ? I can't see it either on the BLF SD button, or on the phone.
GTG
Hey Gordon,
Hope all is well my friend
The following service parameters enable configuration of the enhanced  call pickup features; they display under the Clusterwide Parameters  (Feature - Call Pickup) section in the Cisco CallManager Administration  Service Parameters Configuration window:
Auto  Call Pickup Enabled Configure this service parameter to enable or  disable the auto pickup feature by choosing one of the following  options:
True Set this service parameter to True to enable the automatic, or one-touch, pickup functionality.
False Set this service parameter to False to use the existing call pickup and group call pickup functionality.
The default value specifies False to retain backward compatibility with earlier versions of Cisco CallManager.
Cheers!
Rob
Rob - you're the man :-)
GTG
371
