Mandatory Background Image ?
Is it possible to push a mandatory background image to the phones and lock the setting ?
CallManager Express 4.1
Cisco Unity Express 3.1.1
Cisco IP Phones 7941GE
Thanks !
Silver
Re: Mandatory Background Image ?
Hello Oliver,
Unfortunately this is not possible, unless specified by the user, the phone will use the built-in background which is hard coded on the device load. The only option that I see will be to manually set the new background and then block those settings.
Hope this helps!
I have the same question.
Anyone know if it's possible to do this and how ?
Many thanks
answer remains the same
not possible
java
if this helps, please rate
java
www.cisco.com/go/pdi
316
