Community Member
Manipulate inbound callerid
Howdy,
Is it possible to add a zero prefix to the callerid on an inbound call to a 5300 gateway?
Telco wont add it so we need to.
Any thoughts?
1 ACCEPTED SOLUTION
Re: Manipulate inbound callerid
but you need to modify the inbound calls, so why did you configured an outbound calling number?
translation rules can certainly do this but you need to configure this in the right direction
java
if this helps, please rate
java
www.cisco.com/go/pdi
yes, look at this doc:
Add Prefix to the Missed Call Number
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
java
java
Community Member
Unfortunately we arent using a call manager but a softswitch to terminate these calls.
I've tried putting the translate-outbound calling number translation rule on the voip peer but it still doesnt change the ani.
Any other ideas?
java
java
Community Member
Thanks had it pointing the wrong way. Changed and now working.
Many thanks
211
