Manually adding new Cisco ATA 187 steps required
I am using CUCM 7.1.5 and want to Manually add new Cisco ATA 187 for FAX but i do not find Phone Type ATA187 in the list but i can see ATA 186 please can anybody tell that i need to use any phone type model ex 7960/7965 as ATA 187
1 ACCEPTED SOLUTION
CUCM 7.1.5 supports ATA 187 for sure. Appending details from ATA 187 datasheet below..
Cisco UCM Version Compatibility
• Cisco UCM Versions 7.1.5, 8.0.2, or higher
To enable the device type in CUCM, you need to install the device enabler first on the CUCM & then install the latest firmware released on CCO Download page. Find both files here http://www.cisco.com/cisco/software/release.html?mdfid=283118514&flowid=16101&softwareid=282074215&release=9.2(1)&rellifecycle=&relind=AVAILABLE&reltype=all
cmterm-ata187-qed.9-2-1-0.cop.sgn : is the Device enabler file
cmterm-ata187.9-2-1-0.cop.sgn : firmware for ATA 187
Pls rate the post if it helps.
GP.
1 REPLY
GP.
563
