Community Member
Manually configuring IP Address and TFTP server on Cisco IP Phone
I have a weird situation. We have an IP Phone at a remote site that has not DHCP server on site and the firewall used at the remote site doesn't support any DHCP capabilities.
Is there a way I can manually configure the IP info (IP Address, Mask, Gateway) and TFTP server IP on Cisco IP Phone than using DHCP and option 150?
Thank you!
1 ACCEPTED SOLUTION
Re: Manually configuring IP Address and TFTP server on Cisco IP
You can manually configure the IP address, mask, gateway and TFTP on the phones.
Power the phone up, go to settings > network config
Than unlock the config using by pressing the following keys
Than scroll down till you see 'DHCP Enabled' set it to No. Look for 'Alternate TFTP' and set that to Yes.
Once you do that, you will be able to configure an IP, Mask, Gateway and TFTP on the phone manually.
Community Member
That's exactly what I needed. Funny, wow I couldn't this info easily on the Cisco website. Thanks again!
1547
