mapping Call Manager Route Patterns to Call Manager Express.
Hello everyone I have to convert a very old CCM 3.3 to a CME version 7.
I have only done basic configurations with dial-peers and need a little bit of help translating the route patterns on the CCM to the dial-peer statements on the CME.
I have two ways to get to the PSTN in this location. One on the PRI in the CME and one on a VG200 with FXO ports so I have a lot of dial-peer statements to build.
this is being built in Japan and it looks like their dial-plan length of numbers are either 3, 10 or 11.
Can you please help with these examples?
On CCM 3.3 the route pattern is 0.[2-9]! (using PRI on CME)
would it be this on the CME:
dial-peer voice 500 pots
destination-pattern 0[2-9]T --- does 0.[2-9]! in CCM translate to this in CME?
port 0/2/0:23
prefix ???? can I prefix ranges???
or should I use forward digits all?? or forward digits 11 since this could be the max sent according to infor I found.
On CCM 3.3 the route pattern is 0.0570! (using VG200 FXO)
dial-peer voice 604 voip
destination-pattern 00570
session-target ipv4:10.X.X.X
dtmf-relay h245-alphanumberic rtp-nte
codec g711ulaw
no vad
forward digits 4 (to send 0570 and drop the leading 0)
__________________________________
On CCM 3.3 the route pattern is 0.0041! # BLOCK
Dial-peer voice 702 voip
destination-pattern 0.0041T
session-target ipv4:1.2.3.4 -----send to non-existent target
dtmf-relay h245-alphanumeric rtp-nte
codec g711 ulaw
no vad
Thank you
1 REPLY
Green
Re: mapping Call Manager Route Patterns to Call Manager Express.
port 0/2/0:23
destination-pattern is ok, fwd digits 11 is fine
you can use voice translation rules accordignly
codec g711ulaw
no vad
fwd digits doesnt work in voip dial-peers
u need voice translation rules
codec g711 ulaw
no vad
you can use permission none
in dial-peer
some good examples
cor list is your friend here as well
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con12
1058
