Masking Outbound Call ID on Analog Trunks
Is there a way to mask the outbound caller ID on MGCP configured GS FXO trunks?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Masking Outbound Call ID on Analog Trunks
POTS lines will always get overwritten by telco with the actaul number, you can not mask them.
HTH,
Chris
On your route pattern(s) in CCM under Calling Party Transformations, set the "Calling Line ID Presentation" to Restricted.
Hope this helps.
Brandon
Hi Brandon, thanks for your reply. That seems to work for PRI's and T1's but not for analog trunks. It seems like the carrier over rides any attempt to transform or block the CID.
HTH,
Chris
Thanks Chris, that's what I suspected.
Good info, Chris. Thanks.
Brandon
170
