Matching peer with src route label PSTN failed
I am trying to call 4041111111 from 5051111111 but I get a busy signal. Here's 'debug dialpeer':
Feb 9 20:17:17.074: Inside dpMatchCore:
Feb 9 20:17:17.074: destination pattn: 4041111111 expanded string: 4041111111
Feb 9 20:17:17.074: MatchNextPeer: Peer 8000 matched
Feb 9 20:17:17.074: destination pattn: 5051111111 expanded string: 5051111111
Feb 9 20:17:17.074: dpAssociateIncomingPeer_T: Matching route label PSTN
ACUATL-AS5300-01#
Feb 9 20:17:17.074: dpAssociateIncomingPeer_T: Matching peer with src route label PSTN failed
Feb 9 20:17:17.078: Inside dpMatchCore:
Feb 9 20:17:17.078: destination pattn: 4041111111 expanded string: 4041111111
And there's what I think are the relevant parts of my config.
dial-peer voice 8001 pots
trunkgroup BRIDGE
destination-pattern .T
direct-inward-dial
forward-digits all
dial-peer voice 8000 pots
trunkgroup PSTN
description INBOUND 404 FROM PSTN
incoming called-number 404.......
direct-inward-dial
forward-digits 0
dial-peer voice 1000 pots
trunkgroup PSTN
description BRIDGE OUT DIAL 800
destination-pattern 18.........
forward-digits all
interface Serial0:23
description UPLINK TO PSTN
no ip address
encapsulation ppp
trunk-group PSTN
isdn switch-type primary-ni
isdn incoming-voice modem
no fair-queue
no cdp enable
interface Serial1:23
no ip address
encapsulation ppp
trunk-group PSTN
no fair-queue
no cdp enable
interface Serial2:23
description UPLINK TO BRIDGE
no ip address
encapsulation ppp
trunk-group BRIDGE 1
isdn protocol-emulate network
no fair-queue
no cdp enable
interface Serial3:23
no ip address
encapsulation ppp
no fair-queue
no cdp enable
Hopefully someone can tell me what's going on. TIA
Re: Matching peer with src route label PSTN failed
You have the dialpeer pointed to trunk group PSTN. However, the only interfaces in this trunk group appear to be PSTN interfaces according the the interface descriptions. The two PRI's you have labeled 'UPLINK TO BRIDGE" are not a part of this trunk group. If this is where you are intending to forward these calls, you need to remove trunk group PSTN from under dial-peer 8000 and add trunk group BRIDGE 1.
Hope that helped, if so please rate.
Thanks for the reply. I have tried it with "forward-digits 10" and "forward-digits all". Neither work and still give the same error. Do you have any other suggestions?
Sorry..I edited the post you were reading..I misunderstood your config at first.
Here's what I have now:
trunkgroup BRIDGE 1
direct-inward-dial
forward-digits 0
I still get the busy signal. You are correct, though. Controller 0 and 1 are connected to the PSTN and Controller 2 and 3 are connected to my proprietary bridging equipment. I want to accept 404....... on controller 0 and 1 and relay that dialed number out controller 2 and 3. Let me know if you need more details. Thanks for your help.
What digits are your bridging equipment expecting? Adjust your forward digits statement for forward the digits that the equipment is expecting.
The equipment is expecting 10 digits. I should have told you more. I already did try the forward-digits statement with 0, 10, 7 and all. None of the work. Also, I still get the same error about not being able to match "PSTN" after I've removed that one and changed it to "BRIDGE 1". Here's the error:
Feb 9 21:40:01.087: dpAssociateIncomingPeer_T: Matching peer with src route label PSTN failed
but here's my config:
trunkgroup BRIDGE 1
direct-inward-dial
forward-digits 10
After hours of troubleshooting I decided to put it back exactly like it was before I started and reboot. Guess what. It worked!! This AS5300 is an eBay special so I should have known better. Thanks for your suggestions, Kenneth.
LOL..Im glad you got it resolved. Thanks for keeping us posted and thanks for the nice rating!!
178
