Max blf subscription on a 2921 ISR
Hello all,
I would to know how much blf subscription support a 2921 ISR Router (presence max-subscription).
Could someone help me ?
Note : I don't have this router so I don't need the IOS command to check that. I just need the information which doesn't appear in the release documentation of the router.
Best regards.
MO
1 ACCEPTED SOLUTION
Blue
Sorry I missed the router model.
Out out from my 2921 router
B3R1(config-presence)#max-subscription ?
  <100-400>  maximum subscription supported
Sh diag out put
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 7 ports
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
From my router
HQR(config-presence)#max-subscription ?
  <100-720>  maximum subscription supported
Ronak Patel
Rate helpful posts.
Hello Ronak,
On my cisco 2951, I only have <100-500>. Are you sure your routeur is a 2921 ?
Thank you for your reply.
Best Regards,
Marc
Blue
Sh diag out put
Slot 0:
regards
Ronak Patel
Rate helpful posts.
It seems more realistic,
Thank you very much!
Best regards,
Marc
239
