Community Member
max CAR records
What is by default the maximum no of records stored in CAR database with respect to Call Manager 4.3?
1 ACCEPTED SOLUTION
Re: max CAR records
If memory serves me well that should be 2,000,000 records
Under CAR config you should be able to find this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: max CAR records
java
java
Community Member
Re: max CAR records
u have good memory!
163
