Community Member
Max digits on forward all
Hi all, I have a CUCM 8.6.2 and my users when try to transfer all calls from the phones (with softkey) can digit only one digits.
When I can set the max number of digits of the call transfer?
If I set the CFA from web interface all is working.
Enrico
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
There is no such setting, this must be either pattern overlap issue or Calling Search Space issue, make sure the CSS and secondary CSS on the DN have access to the patterns you are attempting to enter.
HTH,
Chris
1 REPLY
HTH,
Chris
168
