01-09-2008 12:44 PM - edited 03-15-2019 08:08 AM
In my 7940 IP Phones , I need the max line to be 4, but the phone should give busy trigger when one call is active.
I tried by changing the Max line to 4 and the busy trigger to be 1. After doing this, I am getting a busy tone when I have an active call, but the phone is not able to view the incoming call.
I want the phone also able to receive and view the incoming call in the phone display, but at the sametime need to send busy mesage to the caller.
How to acheive this?
Pete
01-09-2008 03:12 PM
It is one or the other, if you want call waiting then you need to set the busy trigger to more then one. If not then there will be no indication to the user.
The max calls will allow him to make outbound calls, so he can have one in and three more out in your scenario.
HTH, Avner.
01-09-2008 09:39 PM
Hi Anver,
Thanks a lot for your reply. So you mean to say like, the busy trigger option enables influences incoming calls and the MAX line option influences outgoing calls.
My requirement is like this.Suppoese the busy trigger option is 2 by default. When a phone is already in call, and the second call is made from the another phone, the caller hears ringing instead of beep sound. So the caller thinks, the user is not picking the call. So can we generate a separate tone for a second call for the caller.
Pete
01-10-2008 12:09 AM
Unfortunately no, have been after this feature since version 3.1 and to the best of my knowledge it is still not there.
Different ring back tone for call waiting is not available in call manager.
regards, Avner.
