Max no of extensions for UC500
I would like to know what is the maximum number of ip phone extensions that can be supported by the UC500, i have the 24user model.
From my understanding; my 24 user model, is capable to support up to MAX 24 IP PHONES. How about the number of extensions?
I am using the IP Phone 7945g, that supports 2 line keys.
Is the maximum extensions dependent on the number of line keys on an ip phone?
Plz advice
  • IP Telephony
Re: Max no of extensions for UC500
Did you try this entering the following command under telephony-service
max-dn ?
It will display maximum number of dn your system can support
What is the maximum number of digits the extensions can have?
Hall of Fame Super Gold
There is no limit. Common sense recommend a maximum of 4.
A show ver will tell you how many user license you get.
The 24 user model gives you 28 or 30 licenses
Under telephony-service run
'max-ephone ?'
'max-dn ?'
To see the max # or ephones or DNs
You should use either 3 , 4 or 5 digit extensions depending on the size of your office and existing dialplan
271
