Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Max. no of Suported IP phone
Dear all,
I have Cisco 2811 with CME 12.T version, the present setup have max. no of IP Phone support is 48, If i want to add more phone what additional license/card or module i need to purchase?
This Box will support more phones or not, i want to know.
AK
Re: Max. no of Suported IP phone
AK,
2811 supports max of:
36 SCCP Phones
144 Ephone-DNs
CME is not a so bug free setup, so i recommend to follow the guidelines from the cisco site:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme402sp.htm
Hope it helped
Regards.
Met.
Hall of Fame Super Gold
Actually a 2811 should support only 36 phones, and will not support more than that (actually a bit more, type ? after max-ephones).
There are no licenses that you can buy to increase that number.
As a workaround you can configure additional phones in SIP, but I would NOT recommend that and you should buy a bigger router instead.
Wat about Cisco 2821 (revision 53.51) with 249856K/12288K bytes of memory.
Is it restricted to 48 IP phones ?
thanks
Aman
Actually 52, because Cisco allow form some excess from the marketed numbers.
430
