max# of ip-phones supported on CME
Some documents say that Cisco 3825 running CME supports 168 ip-phones for maximum.
Is 3825 running CME supported when 168 ip-phones regists into the 3825 and every ip-phone has two or three DNs?
Is there any restriction about number of DNs for CME?
Re: max# of ip-phones supported on CME
There are certainly restrictions for the number of DNs supported on your platform.
Take a look at the document at the following link:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme403sp.htm
The document states that the 3825 supports 500 ephone-dns which should be sufficient for requirements.
Alternatively, another way of checking is form under the Telephony Service, run the command 'max-dn ?' or 'max-ephones ?', these will also show the maximum.
Hope this helps
Allan.
Allan,
Thank you for your advice.
Best regards,
Tetsuo
Hi Tetsuo, no problem all part of the service, thank you for the rating.
Best regards
Allan.
Best Regards
Allan.
726
